Cooling fan rubbing after repairing transmission mount.
If you followed my other thread you know I was working on my transmission which required me to drop the pan and this lead to me pulling the transmission mount and replacing the damaged parts.
Now my fan is rubbing on the housing when I put the car in drive. I have looked at the trans mount and believe I have it installed correctly, but maybe I missed something.
My other thought is when I was dropping the pan and removing the trans mount I may have damaged a motor mount which is allowing the engine to move when in drive thus causing the fan to rub.
Eventually the fan just stopped spinning so I was thinking I needed a new fan clutch so I removed the fan assembly. It turns out the the clutch feels good, but I understand they are difficult to diagnose.
Any ideas???
Any ideas???
Is it a V12?
If not ignore the following guesses:
It is quite hard to ruin the front motor mounts. If the rubbers do become detached from their plates, the engine is all over the place.
Assuming the gearbox mounts are correctly installed, it is more likely that the replacing of the gearbox spring and mounting has changed the forward/aft tilt of the engine; or that when doing the gearbox repair the fan moved the fan shroud on its mountings by fouling against it, unknown to you.
There are four (I think, two top two bottom, but maybe six) small 7/16th nuts to undo to loosen the fan shroud (two/three top two/three bottom). Try doing this and centering it on the (I presume) mechanical fan. Then see if it still fouls in drive. Also get someone else the start the engine and engage drive, while you look at what is happening.
Greg
Greg
Is it a V12?
Greg
Greg
Thanks Greg this sounds feasible. I didn't realize that the shroud had any play in the fitment of it, but I should have guessed it being a British car. Everything with these things seems to have none exacting tolerances LOL! So many things could have been so much easier if they had just put some thought into it during tea time or something over there.
Greg
KarimPA
09-12-2015 08:15 AM
