Cooling system 1987 V12 HE
#41
Received 10,979 Likes
I can't say I've ever encountered a vacuum operated heater valve - one of my other 'classics' has a valve controlled by a cable (solid core wire really), the others the heater coil is live at all times with the temperature controlled by dampers in the car based on human intervention - this is the first classic I've had beyond the Range Rover that actually has AC.
Your Jaguar Delanair climate control is vaguely similar.
All incoming air is first refrigerated and then heated as needed. This is accomplished by sending the refrigerated air through the heater matrix as needed. Internal flaps/doors accomplish this.
In essence the system has four modes: cooling, heating, blend, defrost. The heater valve is open in modes except cooling. Cooling mode is easily recognizable by the center dashboard outlet opening. Typically the system spends most of the time in 'blend' mode.
The following 2 users liked this post by Doug:
Grant Francis (08-21-2020),
Greg in France (08-21-2020)
#42
#43
#44
I've just had to pull out of the radiator which is disappointing, the radiator is clearly for an early pre 1981 car that has the Borg Warner 12 installed, thus it has push on transmission cooler pipes as opposed to the screw on type - so this is quite a rare beast, note that this is in the UK - looks like I don't get a spare.
#45
I have a 115amp alternator and I have been pondering the e fan switch a while... I like the idea of fewer belts and more space. I need to figure out the US equivalent of the fan Grant suggests. Maybe an old Ford Taurus, or sumpthin... Maybe the passat vw idea suggested by Ben. Both can be had pretty easily here.
#46
Grant Francis (08-22-2020)
#47
#48
HAHAHAHA.
The car had to get past the warranty period, then the care factor was ZERO, just like any Manufacturer.
Radiator out and cleaned after 5+ years, waaaay past warranty, they no care, just like changing 1A and 1B sparkers with the Delco Monster in the way, plugs last approx 40K kms, waaaay past warranty also.
We enthusiasts are a SPECIAL breed.
Greg in France (08-22-2020)
