Coollant for 4L
Coollant for 4L
I shall be putting the xjs into hibernation in the next couple of weeks, as the car came from FL and is now in PA, I am concerned about the anti freeze that is in the car now. I have been advised by a friend to replace the old stuff with Evans coolant, which means flushing out all the old coolant with a prep solution and filling up with the non-water based coolant. I am asking the forum on any thoughts or advise as to whether I should do this, are there any problems that I might encounter as to draining the block?
Regards
Nick.
Regards
Nick.
just replaced Radiator in v12 XJS...
used distilled water... nothing else...
now that I have no leaks.... time for OEM coolant...
(was 1.5 gallons / 4 miles...) so that is why I held off on the coolant...
go with the OEM recommended...
enjoy your XJS gem... it will give you more smile/mile...
