Corvette Wheels
Nice, but it will be a difficult fit.
Depends on the year of the Corvette wheels, but their offset is usually in the +50 to +70 range, which will mean at least 30mm spacers.
Here's a site to give you an idea of the offsets: Corvette Wheel Offset Calculator | Corvette Central
Also, width will be a problem, as most Corvette wheels will need 245 tires, and most XJS's can handle only 235's.
Finally, center bore won't be an issue, because the Corvette bores are larger, but you may need a hubcentric ring of a few mm. Also remember that the front grease caps n the XJS make for a difficilt fit.
Also, the video may be misleading, as I don't think there are any 10" and 12" Corvette rims in 18".
But it would be fun to see if you can make them fit.![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Padre
Padre
Padre
Padre
I also read somewhere, IIRC, that the sportspack steering rack allows for wider tires, maybe 245's.
Padre
Since the subject has been raised...
Its much easier, and cheaper to find aftermarket Corvette wheels, with a lot better variety of styles available, compared to aftermarket XJS wheels. I know that spacers would likely need to be used, but, that's not a problem for me. Are there any year Corvette wheels which wouldn't fit the XJS?
Got new wheels from RVRN Wheels
This may be helpful!https://www.rvrnwheel.com
I love the design and I can't wait!
![Confused](https://www.jaguarforums.com/forum/images/smilies/confused.gif)
sempaipaul
06-30-2007 06:49 AM
