Cost to redo all electrical?
Hey everyone,
I'm new to the forum and apologize if this isn't appropriate. I have a 1992 xjs with the 5.3 L V12. The car is generally very solid but has a number of electrical issues that seem to come and go. It looks like a prior owner tried to bypass faults as they came up and just made a mess of the whole thing. A Jaguar specialist mechanic has quoted me 20-25 hours to redo the entire under hood harness. I have seen it and honestly think it needs to be done but does that seem correct for timing? I've just started working with this person and would like to continue, but I want to be sure. Some other work he has done so far has spiraled a bit beyond what was initially discussed. I'd really appreciate any insight.
TweeTwee (10-26-2015)
Spiralling, or mission creep as it is also known as, is inevitable with these cars, especially with the electrics as the looms are complicated, access is difficult and if somebody else has already had a go at butchering it then it could be a nightmare.
However, if your guy is qualified and competent then it is probably the right way to go otherwise it will never work properly.
What specific problems do you have?
The following 2 users liked this post by Greg in France:
Grant Francis (10-24-2015),
Hi Kevin, welcome to the forum and XJS ownership. Once you get the car sorted it will be reliable and the best long distance cruiser bar none.
If the mechanic you are using is going to use an OEM harness I would suggest installing it inside heat shielding sleeve. The issue with the OEM harness is the wire insulation, Jaguar used PVC which does not hold up well to heat.
If the harness is going to be a custom job I would suggest using silicone insulated wire, a little more expensive but will last a life time.
good luck
good luck
The following 2 users liked this post by warrjon:
Grant Francis (10-25-2015),
seawind
11-11-2015 07:21 AM
