crank but no start
Hi Miamijohn
Short answer No
On my own Car when I had that problem, I had to file the holes in the Bracket just a little bit longer, in order to make that adjustment and also give it a little Tap with a Hammer, unless you can come up with another way because if the Gap is Too Wide then it may not work or not work as well as it should do (The Correct Gap is very important for obvious reasons)
As if you lose that Magnetic Pulse on the Toothed Reluctor Wheel, if the 'Jaguar Gods' are not Smiling on you, then it could cause the Engine to Stop just as if you went and Switched it off!
Not an ideal Scenario, if you are in the process of overtaking something at the time!
Short answer No
Sirjagelot (05-07-2022)
CPS update: I removed the radiator and cooling fan shroud for easy access to the CPS. I had the toothed sprocket on the harmonic balancer aligned correctly to the CPS, however even without putting the feeler gauge on it, I could tell the CPS magnet end gap was way too large. The old CPS and the new one are exact in dimensions, so I can only conclude the old CPS has a stronger magnet and thus can pickup a signal from further away from the sprocket. So my question is, Does the barrel end of the CPS with the magnet screw in and out for adjustment?
John
John
Thanks Xjeffs, Yes I have spark from each plug removed from the engine, and the fuel injectors are pumping fuel. The CPS simply tells the ecm when the firing order should occur. So without a cps operating correctly, the spark and fuel injection can occur, but at the wrong time.
John
John
Thanks Paul, no not a silly question as every possibility is worth exploring. So when I set the cams with the cam set tool, I brought the #1 cylinder to TDC. I left the distributor installed, so then the rotor was pointing to the #1 spark plug wire and from there I set the other spark plug wires, running clockwise in the proper firing order. When the cams are set with the tool, the #1 is on the combustion stroke.
John
John
#32
Update: I filed the CPS bracket as OB suggested and I have a 0.030 air gap now. The new CPS is not dead "on center" with the toothed sprocket, but very close. The crankshaft shaft bolt bottomed out, so I could not set the harmonic balancer the little bit deeper. Any suggestions before reinstalling the cooling fan and radiator.
John
John
#33
Before reinstalling the radiator and cooling fan, I gave the engine a quick crank and the tacho bounced to approx 300 to 500 rpm. So I thought the adjustment on the CPS gap worked. So I put everything back together and still no start and the tacho moves very little, just bounces at 0 to 100 rpm. just as before. I double checked the CPS for possible damage and it was OK. I have now disconnected the battery and will leave it that way till tomorrow. My thought is that any residual energy in the ECU will drain away and then when I reconnect the battery the ECU will reset itself. Also is it possible that the CPS must be dead on center with the toothed sprocket to operate properly?
John
John
#34
I repositioned the CPS with a gap of .030 and when cranking the tacho bounces at 200 rpm, so I think the CPS is sending a signal. But still no start, even with starting fluid. I double checked the cams position and the distributor and everything is proper there. As previously mentioned I have 50 lbs at the fuel rail and the injectors are spraying. I have spark at all 6 plugs when removed from the engine. I switched out the MAF sensor but no difference with either one. After sitting overnight and then I crank it, there is a ever so brief firing, which I think is just residual fuel left over in the cylinders. Checked all fuses and relays and they are all good. What am I missing???? As Winston Churchill said, "the yanks will usually get it right, after they have tried everything else"
John
John
#35
#36
John
#37
#38
#40
The only other part that I think could be a cause for concern is the TPS. If the ECU isn't reading that, it won't start.
You've addressed both cam and crank sensors, so we can cross those off the list.
The last thing I can think of, and I don't have an AJ6 engined car, but there is a multi-function (or multi-purpose) relay in the AJ16 that, I believe can cause this problem. I recall reading about this relay....it's all I can think of.
