crankcase breather
Old 10-11-2021 | 09:04 AM
Greg in France's Avatar
You mount it glass downwards, I have just been informed by google! Might be fine.
  #42
Old 10-11-2021 | 09:26 AM
Thorsen's Avatar
That looks like a filter for an air compressor. I would not use it. It's designed to work with high pressure systems, not with vacuum.
  #43
Old 10-11-2021 | 09:48 AM
peckhs's Avatar
Yes, it is supposed to be mounted with the glass downwards..
Should have posted more photos
It is advertised as a engine oil separator baffle tank.. So hopefully it is correct
  #44
Old 10-11-2021 | 11:04 AM
rgp's Avatar
rgp
As long as its air tight its fine for both
  #45
Old 10-15-2021 | 11:12 AM
rgp's Avatar
rgp
All I did was cut the end off the little vacuum valve in the air filter vac pipe blocked up the hole in the filter back plate and took the pipe that used to go straight to the engine breather, after reducing it, to the other side of the filter bowl.
  #46
Old 10-22-2021 | 03:13 AM
peckhs's Avatar
The oil catch tank arrived.
It is small, about the size of a mouse..
I think it should be ok as I remember that there is usually not much oil in the oil catch can...
And I may not need to mount it, just leave it in between the hoses from the pig snout to the air box?
  #47
Old 10-22-2021 | 04:54 AM
rgp's Avatar
rgp
This was my set up.
Mounted in the brace
From the breather
To the original inlet,
I cut the cut the end of the pcv valve and blocked up the air cleaner hole. Trouble was it made me a bit paranoid so i reverted to original set up with a new pcv from a pinto (cheap) It made no differance to tick over when fitted and only caught dirty water.
  #48
Old 10-22-2021 | 08:14 AM
peckhs's Avatar
Originally Posted by rgp
This was my set up.
Interesting.. You fabricated the round holder?
  #49
Old 10-22-2021 | 08:29 AM
rgp's Avatar
rgp
It's a stainless badge bar clip. If anyone wants to go down this route this set can go, pm me if interested.
peckhs (10-23-2021)
osyris
06-04-2016 04:46 AM
neemo
07-23-2010 02:08 PM
turbo68
05-08-2010 11:47 AM
skanoski
03-31-2008 08:29 PM
Quick Reply: crankcase breather
