Crap...my cat wet herself.
ptjs1 (04-02-2022)
The following 2 users liked this post by malc4d:
Grant Francis (04-11-2022),
Greg in France (04-11-2022)
The following 2 users liked this post by Greg in France:
malc4d (04-11-2022)
Received 9,302 Likes
The following 2 users liked this post by LnrB:
Assuming you mean the one with the shroud and fans all together?
The first thing is to remove the no longer required mechanical fan, it's boss and its tensioner, and also by doing so you save a drive belt. This can be done without removing anything else, but you might have to cut the belt, I cannot remember if it is the first second or third! Removing the power steering belt is a royal pain so cutting the belt, if needed, is a good option.
You will find, after the fan boss is removed, that the studs which are freed up and also hold part of the water pump, are not threaded down their whole length. So either get some spacers or thread the studs further down. I lazily used spacers (large nuts) and they have been there for 20 years!
Now the fan is out, you can undo the old shroud (fixings top and bottom). The ebay ad said the new unit uses the same fixings and drops straight in. The next thing is to decide how to control the fans. In my experience ALL the aftermarket stuff fails on the V12 in the XJS; but the good news is that Grant has a SUPERB control system that uses the OEM parts already on the car. This works reliably and properly.
In brief it works like this:
The new small fan replacing the OEM electric fan is wired to come on with the aircon condenser.
The big electric fan replacing the mechanical fan requires you to add a relay (use a 40 or even 70 amp relay as the current draw is big). The power side of the relay you wire to draw current from the firewall positive post. The relay is triggered by the OEM thermostatic switch in the water pump inlet. I take current from the coil 12v input to power the trigger side of the relay. I also installed a second cabin-switched circuit for the main fan, just as backup.
If you decide to go ahead, Grant has a diagram and so do I.
Grant Francis (04-12-2022),
malc4d (04-12-2022)
malc4d (04-12-2022)
