Cruise Control - Full speed ahead... literally !!!
Just like the title say... when I turn on my cruise control the car starts accelerating and does not stop unless i turn it off.
Any idea where to start?
I have not looked at the adjustment pots yet, or tried my light setup but will be.
Not sure if this is the same issue, but it might provide a place to start looking.
XKS Unlimited Tip
XKS Unlimited Tip
Received 10,979 Likes
Here's some reading that might cover the problem
Cruise Control
Also, there's an adjustment to 'trim' the cruise control speed. It's on the cruise control module. My gut feeling, though, is the problem you're describing has something to do with one of the little valves in the cruise control servo assembly. The article linked above discusses the valves
Cruise Control
jerry_hoback (05-04-2020)
XKS Unlimited Tip
XKS Unlimited Tip
The one on the left im front of the yellow box cap. While driving is best..turn it counter-clovkwise to reduce the engagement speed. A little goes a long way. It's a fiddly business..you need an assistant. if you go too far the cruise won't engage so you can verify that this is the culprit pretty easily.
I've read about the access port thing. Mine doesn't have one for sure. Maybe they added it later..or took it away?
Kaibigan
05-01-2012 05:09 AM
