Cruise control problem
Hi all,
I would appreciate any help regarding an issue with my cruise control, it works fine, sets, increases speed & disengages, but will not resume after a disengage, however it will again allow me to set a speed.
To me it would appear that the mechanical side is okay but the electrical side has a fault.
Any ideas please?
Any ideas please?
Received 10,872 Likes
It might help you to know that it's the black/slate wire that gives the "resume" function. With the switch pressed to "resume" the wire should be grounded/earthed
Often the switch can be (gently and carefully) opened up to clean dirty contacts. If you determine (or even suspect) the switch is at fault you might give it a go before spending money on a new one
Mkii250 (08-12-2013)
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
