Custom exhaust system
RE: Custom exhaust system
Try Craigslist, Columbus Ohio. There was a guy in Zanesville trying to sell an aftermarket exhaust system for like an eternity, and I think I saw it still on there recently. If you see an ad for an XJS for sale in Zanesville, I think you found the same guy. I believe his car and parts were V12.
On a side note...my Dad graduated from PSU after after his WW II service. Guess who was an assistant football coach at the time? Yep, both of those old Lions are still around.
I have mixed feelings about full exhaust system kits, brought on mostly by the price tags. The one I've seen range from about $800-$1200.
Make friendly with a good exhaust shop and select some decent mufflers. I agree with Benito that the OEMpipes are sufficient, for most of us at least. I just think its a bit much to replace an entire system when 90% of any difference is gonna come from the mufflers themselves.
Of course, if the entire system in shot, that's a different story.
The stock system is in very good shape. The aftermarket system that I looked at was $1400. The main difference is that it's full 2.5"diameter piping. Also comes with "high flow" cats/mufflers. I want to be able to feel and hear a difference in performance from the V12!
There is a custom shop in the area that I am familiar with. I just don't know if the cost of having customworkdone would be equivalent in the end to just purchasing the system already fabricated.
How much does the size of the stock piping (2", I believe?)restrict the V12's performance? Are the rear resonators very restrictive?
I'm sure there's a lot of science to pipe diameter and I certainly am noteducated on the matter.
The rule of thumb I've gone by is that 2.5" pipe is needed with big engines....like 350 cubic inches, 400s, 455s, etc. In fact some of those big V8 guys to to 3" or more for the real hot rods.
Your V12 is 326 cubic inches. Personally I just don't think the bigger pipe is needed and it might even reduce the scavenging of the exhaust be end up being counter-productive.
Other will chime in.
I'm guessing a typical muffler shop can fix you up with four good quality low restriction mufflers for $500-$600 installed.
With the money you savehave them install an "H" pipe to bring out the true V12 sound.
Yes, I amone of those "big V8 guys" My Camaro is 346 c.i. and I run a 3" exhaust with a modified engine, my Corvette a stock 350 and I believe it also has 3" piping. I know that there is a risk of running exhaust "too big" for the motor, losing backpressure and reducing exhaust scavenging. I guessthe XJS boils down to2" of exhaustper 6 cylinders, which might be about right; technically though, I don't have proof or numbers.
Defintely want to usean "X" or "H" pipe in the system, both for sound and to equalize pressure between banks.
Again, what is the purpose of the XJS dual rear resonators, after the mufflers? Are they just to quiet the exhaust note? It doesn't seemthey would have an effect on emissions or anything else. Could I eliminate them altogether?
$1000 give or take isn't very reasonable in my opinion and this may not apply to you but here's why I decided what I did, when looking at the piping on my car 2.5 in is more than enough for me, also the bends in the stock system appear to be mandrel bent and not restricting flow in any sense whatever. For the V-12 2" pipes per bank isn't too bad, if it's mandrel bent, if it's pipe bent and gets all crimped around the turns then in my opinion I would replace it, if the it looks straight then just put in a good set of mufflers and it'll do plenty. On mine the rear mufflers were already straight through so they're just muffling not impeding so I decided to leave em so all I had done was have the first set of mufflers replaced with a set of straight through performance mufflers. And straight through is straight through so pick the muffler according to personal preference. The H pipe is a great idea, and any shop worth their salt can do it. Either way talk to a good shop before you drop a grand or more on a pre made system.
ORIGINAL: PSU 98
Thanks for the advice everyone, I guess it wouldn't hurt to talkto the local guy about the exhaust system before I buy anything. He's afellow car club member so I think he'll be willing to help me out.
I also found this quick link re: exhaust size while browsing for info: http://www.magnaflow.com/wideopen/performdata.asp
no it's in the same exact spot, he ordered a muffler that is offset inlet, center outlet, which I know is not the same, and is like an inch longer than the stock muffler, but there was enough room where the hanger met the grommet to push the whole rear section (from the muffler back) about an inch or so and it all cleared and came out great
Car runs like dream machine, and sounds like a small plane on takeoff when I am merging on the freeway.....................love it.
Wolfy
05-28-2024 09:06 AM
Aus V8S
11-13-2015 12:01 PM
