Damper pully
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
Damper pully, harmonic ballance, the one behind the crank pully the outer ring turns freely,what does it do has a PDC sensor on it but it can't have anything to do with timeing it turns by hand. I turned it, it's conected by belt to the alt. Do I need to put it back where it was if so what marks do I go by. I just need to know before I try to start. Please help answer here or e-mail at arthurbennett1@msn.com
Thank you Art
Thank you Art
arthurbennett1 (11-28-2014)
What year is your car?
If it is V12 with marelli ignition, the timing is controlled by the 3 finger set up attached to the rear of the hub. That is solidly attached to the hub in such a way that delamination will not affect the timing. You most likely will have reduced charge rate from your alternator though.
RoyLittle0
05-25-2023 02:38 AM
Woznaldo
09-26-2015 11:02 AM
Tar
09-06-2015 11:24 AM
