Dana differential output flange studs
Does anyone know how the Dana (not Salisbury) output flange studs are retained in the flange? They do not appear to be welded, and I'm hoping they are just pressed in and can be removed with an air hammer.
I've converted to outboard rear brake discs on my '87, and some material on the stepped center needs to be removed from the flange so I can get the correct amount of negative camber. If I can remove the studs in the car, I can use a cut off wheel on an angle grinder to remove a portion of the step.
I will check tomorrow if nobody else replies. I am pretty sure they are push-fitted though. Whatever the system is, it will be the same as on the Salisbury diffs.
One other way of achieving your objective would be to just use a thinner spacer. The outboard cars had to have a spacer in place of the thickness of the (no longer there) inboard disc. It would e easier and maybe safer to get that spacer milled thinner.
I have all kinds of spacers. The fact is the spacer locating step in the center of the output flange is too high, and interferes with the step on the halfshaft flange. As a result, with all spacers removed, I still can't get enough negative camber, and I end up with a large gap between the mating aurfaces of the flanges. The halfshafts for outboard disc cars are completely different than inboard halfshafts, and are effectively longer when installed the make up for the loss of the inboard discs. I need to remove about .080" of the step. I won't touch the mating aurfaces at all.
Greg in France (10-23-2021)
Greg is correct.
Push on, like any wheel stud, with a knurled section just under the head for flange grip.
My memory is off, but I dont think?? there is enough room between the rear face of that flange and the bearing housing to remove those studs, BUT, its been YEARS, and I cannot find my :spare: Salisbury stub, so it is a best guess on my part.
THis nis the DANA stub axle when unbolted.
The studs can be pressed out.
Grant Francis (10-24-2021)
The following 2 users liked this post by jal1234:
Grant Francis (10-24-2021),
Greg in France (10-24-2021)
I really would not do that. All you have to do is undo three fixing bolts into the diff and the entire stub axle just pulls out. Then you can work more easily, and without any danger to the diff casing, on the bench.
Greg in France (10-25-2021)
