Dash indicator lights not working
I have a 1995 XJ-S 6.0 V12 which I have just purchased. Although externally all lights (head, direction, brake, etc) are operative, none of the 20 dashboard lights are working?
Looking at a wiring diagram I found online, it seems that there is a 7.5 amp fuse located in the main fuse panel (LHD driver's side panel). Could this be the problem?
any other ideas, thoughts or suggestions would be really appreciated as I'm concerned that without check engine lights working..who knows?
ll be back to the XJ-S next Sunday and with fingers crossed, will indeed twist the rheostat a few times and hopefully....Voila!
I'm not sure if this reply will be seen by all (Greg, Orangeblossom, JigJag etc) but having revisited the illumination issue, I feel a little stupid. It turns out that all the dash illumination was working HOWEVER, it was not until it became dark in the evening that the dash lights became visible. The dash lights are SO DIM that in daylight, they are not visible other than on start-up. Once the engine is running, all "status" lights extinguish BUT, when it became dark I was not able to see the direction indicators flashing. At night, no problem. The dimmer rheostat works fine (at night). Do I need to fit LED lights or just grin and bear it?
Just seems odd to me that these indicator lights are visible on start-up but, when extinguished, are just way too dim?
Thanks Ronald,...also I seem to have read somewhere that LED replacement bulbs don't just pop into the old incandescent socket as they require a different resistance?
I still think there is a connection somewhere that is dimming the lights unless the headlights are selected. I'll chase that one down.
Chris
Chris
The bulbs I used in the warning light strip are B8.5D-A for standard brightness and B8.5D-AHP for high brightness. I used amber, yellow, green and white. For the instrument lights I used a 195 in place of the 194. you will need to purchase five 194/195 bulb holders because the lights you will remove are a one piece bulb and base. I did not use LED in the 195's. Purchased those and the bases at an auto parts store.
https://www.superbrightleds.com/cat/...pe,B8.5D,1,28:
annamiata
12-08-2019 02:56 PM
Famous Jerry
07-13-2013 06:17 PM
