dash lights
I just obtained my 1995 XJS VP. and the dash lights are not working,I have checked all fuses, all o.k. i have been told it is the headlight switch. when i turn on the headlights, they work ok. the dimmer switch is also working ok.
could it be the actual light switch located on the side of console. or is it the switch that also controls the running lights/trunk release ? any advise would be appreciated..................this is a great forum for assistance.... thanks everyone.
whiteheather (03-30-2011)
Received 10,876 Likes
Is it *only* the instrument cluster illumination that is inoperative? Or is also the window switch illumination, climate control buttons backlighting, cigarette lighter backlighting, etc?
They all work of the dimmer switch at the side of the steering column so if *any* of them work it suggests the dimmer switch is OK and the problem is dwonstream of the dimmer switch, possibly at the instrument cluster itself.
If *none* of them work it suggests a faulty dimmer switch or a problem upstream of the dimmer switch.
If you have a test light or meter some fairly easy tests could be made
PS-hopefully this will all get moved to the right section
whiteheather (04-02-2011)
it seems to be all lights with the exception of odometer , ironically i have ordered a new replacement dimmer switch, as there are no lights on window switchest also. many thanks, i have called my mechanic who is working on the car today, and he will do the test light sequence......again thank you
whiteheather
whiteheather
![Icon Bike](https://www.jaguarforums.com/forum/images/smilies/icon_bike.gif)
My licence plate light lense has dissapeared, the kight fixtures are there, does anyone have any idea where i can purchase the 2 light lenses or the complete fixture. i live in B.C. Canada....any help would be appreciated.....many thanks
Whiteheather................
Any idea what I broke?
![Stick Out Tongue](https://www.jaguarforums.com/forum/images/smilies/tongue.gif)
jagent
09-12-2015 01:40 AM
02jagstype
09-04-2015 08:20 PM
