Dash lights out
Greg in France (05-01-2020)
Hi Brinny
If you're going to remove the Speedo Binnacle in order to check the 2 Multi plugs on the back, this is how I did it on my Car, including loads of photos and a Step by Step Guide, just be very careful that you don't damage the Printed Circuit which is on the back
Where other than that removing the Speedo Binnacle is a very easy job but only after the GF told me where I was going wrong!
Also may come in useful to others with 'Speedo Stopped Working' problems or anyone wanting to upgrade the Dash Lights with Brighter Bulbs
Here is the Thread: How to remove the Speedo Binnacle on a 1989/1990 XJS V12
Thanks for the assistance OB. I've had the clocks out and had a look around. Nothing obvious but then I'm no electrician! Both the plugs properly connected. I followed mr palms advice and added another earth. Gave the printed board a good dousing with electrical cleaner as well as the plugs. Put it back together and got a few lights as per the photo. What now??
Received 10,916 Likes
I'm not entirely sure that you still have a problem. Which warning lights, specifically, are not working?
It's been years since I owned an XJS but I'm pretty sure that not all of the icons are intended to light up with the key 'on' or 'key test' mode. Actually, I recall that, on my XJS, not all of the lights/icons were intended to light up at all. I think there is some variance according to market and/or equipment/build spec
Hopefully someone with better info will chime in.
Thanks greg. I'm just looking in the handbook now. I've had some success here because they had all gone yesterday. Maybe everything is on that should be.
They just pull out Brinny, they are T5 push fits and normal bulbs are recommended, and do not have to be put in any particular way. I would chnage them all! eg:
https://www.ebay.fr/itm/10-X-286-T5-...-/372303232722
Hi Brinny
'Greg' also recommended these bulbs to me which are not LED but are rated at 5w to make the Dash Lights Brighter
Also in the same thread, how to replace the Ariel Grommet if you ever need to
Brighter Bulbs for the Dash Lights plus how to replace the Aerial Grommet
Greg in France (05-03-2020)
BUT, inside the white part of the cluster (which you remove from the black part by undoing 5 or 6 small self tappers) you will find that the illumination bulbs have dark green top hat filters over them. Remove these, then screw the black and white parts together, then insert the 5 watt T10s, then your cluster illumination will be transformed - you might even have to turn down the dimmer!
OB's thread is good on this, too.
