Dash trim
Time-Pilot,
When did the speedo start "bouncing"? Is it a big bounce or small fluttering? It may well be your speedo but also the speedos are very sensitive to the air-gap at the sensor in the rear diff. Although it shouldn't change if it's never been disturbed, the air gap is critical and is shimmed with very thin nylon shims where it mounts to the case. It's fiddly to access but quite feasible to carefully remove it and add or remove shims to adjust. After my diff was rebuilt, I had to remove one shim to stop the speedo fluttering at low speeds.
Good luck
Paul
Good luck
Paul
al_roethlisberger
08-07-2016 02:49 AM
1964Daimler
08-28-2015 06:20 AM
