Dash veneers...
Dash veneers...
('93 convertible) A crack in the finish on the glove box veneer and a chip in the trip computer surround veneer has me searching for repair/replacement options. Is it possible to refinish just these two pieces and have a reasonable match to the untouched pieces? The other option is to replace the side vents, centre vents, glove box (no air bag) and trip computer surrounds. Obviously, more expensive and would I then have issues with matching the instrument surround and ski slope? If I pursue the later option, can I buy these pieces pre-made or do I need to remove the existing pieces and then send them somewhere to have them re-veenered and finished?
If best to pursue the replace or re-veener option, anyone have a recommendation on supplier? I've seen Britsh Autowood, CG Woodcraft and Jaguar XJS Interiors (in GB).
Thanks,
Thanks,
Personal experience with British Autowood. They are excellent.
You could always call Saul at British Autowood, send him a couple photos, and just ask his recommendation. Based on my interactions with him I don't think he'd try to upsell you something you didn't need.
Cheers,
- Will
Cheers,
- Will
DenverDRS (09-10-2012)
Another option is to cover the existing wood with a Mactac oak burl peel and stick type film. This, of course, depends on whether you want the OEM materials or not.
I suspect this method will simply just not do for Jaguar owners.
OTOH there is this.
Walnut Burl Veneer Deals @ Veneer Factory Outlet.com, Wood Veneer
I have not checked into this as part of a quest to loose the ashtrays and fit cupholders.
Gerry T.
OTOH there is this.
Gerry T.
I stripped and redone mine, but then I changed the veneer completely and used a water fall babinga wood veneer. it is time consuming and for some parts you need some kind of vacuum bag
vacuum sealed. Do not own a regular vacuum pump and bags. A bit of ingenuity, use a Space Bag and my shop vac LOL
10 coats of Polyacrylic, applied by brush, hand sanded between coats. 4 coats of spray on Ploy, followed up by 4 coats of Liquid Glass polish
012
012
http://stores.ebay.com/jsowoodproducts/
Fletch44
09-28-2015 02:21 PM
