Dash Vent Gaskets
Dash Vent Gaskets
Subject: 1996 XJS
Over the last year or so, while running the A/C, when you first turn the A/C on high, tiny pieces of sponge like material blow out the vents on the dash. Especially the center vents. It only happens when you first turn on the A/C. I'm guessing they are pieces of soft, foam gaskets just behind the black vents that are starting to dry rot. The car only has 55K and has been garaged all it's life. But then, it's 27 years old.
Can these gaskets be easily replaced ? What is the best way to remove the vents without damaging them ? Thanks for any help.
Jaguar lined the ducts with this foam to make air flow quieter. My car is nearly 40 years old and just now whenever I start up the AC there are no foam bits... Unless I've been messing with stuff, in which case I again get showered in foam dust.
But it is annoying, especially when one is Dressed for an Occasion and these little bits of detritus cover ones dress-up clothes.
I'll have to check that out on my 96' and see what I have. The pollen filters may have started to disintegrate due to age. What was coming out of my vents were tiny, black colored pieces that looked like sponge rubber.
So maybe it's the pollen filters versus the sponge around the vents ? Or both !! LOL.
rgp (10-08-2023)
rickr (10-08-2023)
Tks so much for that!
I would apparently need JLM11696 for my late car. However, strangely, not one of those part numbers is listed by Jaguar on the parts website (even despite now having seen a photo of the box and the part number stamped on it!) I'll give them a call tomorrow and try and get to the bottom of it.
Paul
OK. So noted. Thank You. Shows the value of belonging to a Forum such as this one.
K.Westra
05-06-2020 11:22 AM
