Dashboard failure
Dashboard failure
My car has been sitting for 15 years. As you may guess, major electrical issues. I got the headlights working and some other stuff, but the dashboard is still not working. The voltmeter and oil pressure gauge are working. Tachometer, gas and coolant do not move. Any good ideas where to look? I checked the main fuse box on left blower and it seems fine.
Received 10,979 Likes
Problems with the PC are so common I'm tempted to say that, by now, every old XJS has had this ritual done or needs it to be done.
Segfault (07-07-2018)
Hi Segfault
The Rheostat only affects the illumination inside the Dashboard 'Binnacle' where the Rheostat Knob can be Rotated to dim the illumination, or if turned all the way round can turn it off altogether
That's its only function (basically its a dimming switch) and doesn't do anything else, where in the event that it ever goes wrong then that is probably down to a bit of Corrosion, as once its been set in a position that the driver prefers
It seldom or ever gets rotated again, so in the event that the illumination decides to go out, twisting it round a few times in both directions should get it working again (But it doesn't go all the way round!) don't try that or you could break it off.
As has been already said, your problem is almost certainly caused by Corrosion on the Tangs of the Two Multiplugs, that plug into the Printed Circuit on the Back of the Instrument Binacle
And although taking the Binnacle out is a very easy little job, you need your 'Watchmakers Head' on and be extremely Careful that you don't damage the Printed Circuit, as you can't go and buy another one
It took me Two Hours to clean those plugs and get the Plugs Tangs looking all nice a Shiny, as the Binnacle is one of those things you don't want to keep disturbing, if you can possibly help it
You can see how I pulled the 'Binnacle' out on Page: 76 of my 'Cherry Blossom' restoration thread, which I had to do to Fix my Speedo, which suddenly stopped working but after cleaning those Multiplugs, I did get it working again
Here is a link to that Page: Taking Out The Speedo Binnacle
Segfault (07-08-2018)
Thanks! I can handle fragile electronics no problem. I actually removed the PC and inspected and cleaned it. Same with multiplugs. I added an additional ground wire. No change whatsoever. Speedo is working, oil gauge and voltmeter are working. Tachometer, gas and coolant temp are not. The next step is to start checking all wiring that comes to multiplugs, methinks. This is a long story, but there were some attempts made without my authorization to fix this car. I think some monkey screwed something up. Makes it even harder to troubleshoot.
orangeblossom (07-08-2018)
The gas float is indeed made of plastic and through some strange and mysterious (to me) form of osmosis absorbs gasoline over the years despite the fact that is is sealed. I've never understood that but on every xjs I've pulled the fuel sender unit out of, it's like half full of gas.. I'd pull the sensor and operate the arm manually and see if the gas gauge responds.
Of course the beauty of this job is without a gauge you don't know how much gas is in there, and therefore don't know if the fuel level is below where the sending unit sits.. oh joy :-)
ABALaw
04-14-2023 07:37 PM
eshea
03-24-2022 10:14 AM
jjohns26
16
01-09-2013 05:13 AM
03-18-2010 04:41 PM
