A day in my short life as a Jag Owner.
If you have read any of my other posts you know that I have had an interesting beginning to my Jaguar ownership.
Well today was another interesting one to say the least.
I finally had the trans issue sorted which was the kickdown switch being stuck and finished installing new plugs cap and rotor and checking the centrifugal advance which was good.
So I took the car for a little trip to the car wash and decided to pressure wash the engine, which I have done to hundreds of cars.
Out of all of these cars only two have had issues afterwords. one was a volvo and the other of coarse was the Jag,,
The car did start but was running on a few cylinders which I wasn't surprised buy considering the way the wiring harness is made.
so I parked it adn went across the street for some lunch and to let her dry out a bit.
I came back and started ehr up and she was running better but still not on all 12 so I began to drive around the parking lot to see if things got better.
At this point I became aware of some smoke coming from the hood and stopped to look,,
What I found was a fire at the back down near the transmission!!!!!!
I ran to the gas station and grabbed a fire extinguisher and ran back to the car and had the fire out with a single blast from it.
After a look I found that the vacuum modulator hose had melted on the cat and caused the fire, the car still ran and I was able to drive home, without shifting of coarse without the modulator.
So I came home and replaced the hose and went out for another ride and all was well for a while. At this point the car started smoking very badly and I thought it was on fire again.
It turned out to be that the vacuum modulator had been damaged by the heat from the fire the I was sucking the trans fluid into the right intake causing the smoke, hilarious!!!
I still haven't driven the car for more than 10 minutes without having some major issue with it, but I will get there! It is a very nice car that just hasn't had the basic maintenance done so I am catching her up...
Long Post ,,,,,,,,
Long Post ,,,,,,,,
MC36
US Lower Atlantic
09-01-2015 07:34 PM
