de-pressurizing brake system (replace accumulator)
The following 2 users liked this post by Jagsandmgs:
orangeblossom (08-06-2017),
tomtomterrific (08-06-2017)
The following 2 users liked this post by sidescrollin:
Mission accomplished! I got an allen key ratchet head. Pumped the pedal once hard while running (this was where I would get the brake and abs lights), held the pedal down, turned off the motor, pumped brake 25 times, removed the old accumulator. No pressure, and only a couple of drops of fluid dripped. Fastened on the new accumulator, topped off brake fluid. Started engine and got a brake warning light. I t went off after a minute and a few pumps of the pedal. Drove it around and the brakes are much better. Did a few panic stops at pending lockup, at 50 mph and all is fine. I didnt actually lock them up to see if ABS is working but my warning lights are gone and the brakes work well, Thanks Gents!
