Dead radio
Thanks for looking, as the title says my radio is dead. I replaced an old pioneer cd radio, with a newer aux/bt. I got it working and went to clean everything up, and plug it back in. After doing so, I would hear the antenna relay in the trunk turn on, but the radio stayed off. I checked all fuses, and the inline fuses near the radio, and trunk. What did I do now...
1986 Jaguar xjs 5.7l
Yes, and i tested both radios afterwards, neither fuses blew. Checked my fuses under the dash with voltmeter and came across 2 with no voltage but did not blow, I have no panel with labels so I don’t know which is which. There is no juice going to the constant 12v neither.
Greg in France (07-26-2020)
Bad ground to the main plug for the 12v hot and antenna. Took off my vent interior around the gas pedal and found a ground, took my ground from the plug and grounded it there. Turned on.
