As many of you have read, I am trying to get this car ready for our first 800 mile road trip in five weeks. I have been patiently going through the cooling system in hopes of having the trip go uneventfully.
Well, while replacing the radiator, thermostat, belts and hoses, I found the thermostat housing very corroded and heavily pitted.
I ordered a new OEM thermostat housing but when it finally arrived, the packaging label was mislabeled (part inside was wrong). Now I may be facing yet another delay in getting the car back together.
However, since placing the order for the new housing, a Jag specialty shop has seen the old housing and said it could be reused. They suggested one of the three following measures:
1. Coat the hose contact area with tire bead sealer, let is set for a few minutes until tacky, then put on the hose and clamp
2. Coat the hose contact area with Permatex #2, let is set for a few minutes until tacky, then put on the hose and clamp
3. Use two hose clamps, side by side
Attached is what the housing looked like after removing all the corrosion.
I know I am not the first to come across this situation, so I would like to hear your opinions.
Do I need to wait, to get the correct new part (from somewhere) or do I use the old with a method described above?
PS: Don’t blame me for not changing the coolant regularly. I only bought the car two year ago.
I have refurbished many a lot worse than that using JB Weld, the standard long dry stuff, NOT the fast dry junk, and a when dried (24 hours) sit down with a file and reshape it. The filing will depend on how good you are at applying the putty. The smoother the application, the less filing is needed.
Clean all those pits with a solvent and a toothbrush, and whatever you use will "stick" good and proper.
Reason: spelling still sucks
