Delanair mkIII & defrost/center vent operation
Hi All,
I'm finally getting round to trying to diagnose why my center dashboard vent never opens.
Does anyone know if there is any sort of mechanical linkage between the windscreen defrost vent mechanisms & the center dash vent mechanism, or can they operate independently?
I've been testing the 2 vacuum solenoids behind the right hand side lower vent panel.
- the center vent (black tube) one is definitely working - it switches vacuum on when heater is on max cool, & off when heat turned up. Center vent doesn't open though.
- the defrost (green tube) one doesn't appear to do anything, but maybe I haven't tested it fully yet. I'm not sure under what circumstances it should activate. I tried crossing them over & connecting the center vent solenoid to the green vac tube for the defrost vents and it did close them off when under vacuum so the defrost actuator/physical side of the defrost mechanism does at least appear to be working.
I'm just trying to work out if my center vent apparently being stuck is linked to the potential defrost solenoid issues, or if I just need to somehow physically force the flap open/unstick it to get it working.
Asdrewq (06-15-2023)
