Diff Speedo Wiring
Diff Speedo Wiring
I've done some reading but didn't find a concrete answer in the forums.
I have an 83 with an electronic speedo that has the two-pronged connector (pictured below).
I just recently installed a 3.54 diff from a 95/96 XJS, which has a diff speedo sensor. Its connector has three wires and looks like this:
Should red to to red, white go to white, and disregard the blue? Or maybe blue is an independent ground?
Before anyone asks: I can't utilize the standard trans-driven speedo because I have a manual T56 transmission (it has a speedo sensor of its own but I couldn't get it to work, even with a Dakota Digital box).
- Anderson
- Anderson
Received 10,872 Likes
The following 2 users liked this post by Doug:
JJS- Florida (05-24-2024),
orangeblossom (05-24-2024)
Doug's correct. You need the interface box, and a different speedo for the diff mounted sensor. Your existing trip computer will work with the interface box. The interface box has two outputs, one for the speedo and one for the trip computer. You'll need to rewire things to get everything to work, since your existing speedo and trip computer share a signal wire. The interface box sendctwo different signals. The best thing to do is get a wiring diagram for the speedo and trip computer for your car, and one for the later cars, and compare the two. I had to do it, and it took awhile to figure things out.
Jon
Jon
The following 3 users liked this post by jal1234:
Greg in France (05-24-2024)
I appreciate everyone else’s responses, but I’ll admit - that sounds like more work than trying to get the T56 signal to work.
see below. Factory Jaguar transducer installed into TKX
The following 5 users liked this post by nickr76:
Doug (05-24-2024),
Greg in France (05-24-2024),
MrAndersonGCC (05-24-2024),
Thanks Nick.
I sent an email to Bowler to confirm it will work with an LT1 T56 (their description mentions the magnum, tko, and tkx but not the old LT1’s).
My other concern is how much room I’ll have to clear the trans tunnel. In your picture it looks like the bowler adapter is pointed downwards maybe 45 degrees. The lt1 speedo sensor is mounted straight inwards, parallel with the ground. I don’t know if I’ll have room to clear the tunnel with the bowler sensor and transducer attached.
Here’s a tkx sensor circled:
And an LT1 T56 sensor (the oem electrical sensor has a 90 deg bend, but obviously the bowler adapter that would take its place is straight):
nickr76 (05-25-2024)
Guess it’s back to trying to get the Dakota box to work.
Q: Do both the red and white wires running to the speedometer from the stock sensor carry a speed signal? If not, which of them should receive the signal from the Dakota box (or should I splice them together)?
