Differential oil
Received 10,980 Likes
I use any name brand 80/90 GL5 gear oil. Some already have a limited slip additive and will say so. If not you'll need to buy some. The GM part number is 1052358 but (here in the USA, at least) every local parts store carries an equivalent.
I think the capacity is about 2.25 US quarts
Someone with a manual close to hand will verify
ronbros (03-03-2018)
Use Castrol Syntrax LSD, this is the best and most easily available in the UK. Do not use non-LSD diff oil, they are not the same.
Most places have it.
IMO, leave it alone. But, I have a pretty high degree of tolerance of oil leaks. I only go after the gushers. Oooozers and tiny-drippers I ignore on any old car.
ronbros (03-06-2018)
Brinny
https://www.amazon.co.uk/Castrol-Syn.../dp/B008R78YCY
Greg in France (03-04-2018)
I'm quite surprised that this is the only thread on the differential I can find. I want to learn more about it and what oil, how often to change, etc. but this is the only one I can find. Surely there are others?? I'm wanting to learn how to do it myself after checking to see if it needs to be done.
My solution is to change the diff oil every time I have the rear axle out to fix the brakes or something else. Seems to happen about every few years...
You must used diff oil specially made for LSDs though, as noted with an example in the posts above.
First and foremost, never remove a drain plug on anything until you are sure you can also remove the fill plug
Reaching the fill plug for checking the level or adding oil can require some contortions but it's doable. Removing the tie-plate helps quite a bit, in my experience....but doing so is, in itself, a bit of a chore. Lots of fasteners.
Before removing the fill plug brush away any debris/dirt in the area so it doesn't inadvertently fall into the hole
To top-off or re-fill I use a rubber hose hose attached to the bottle of diff oil and just squeeze the bottle to push the oil through the hose.
The filler hole is just a couple inches below the sensor. Item #3 in this illustration id the filler plug
https://www.jaguarclassicparts.com/u...mbly-5-3-litre
orangeblossom
02-28-2016 04:35 PM
