Distributor Cap Hose Routing
I just bought a 1989 XJS Convertible and I am in the process of fixing all of the issues that have been neglected or improperly repaired.
One item I have noticed is that there are no hoses connected to the distributor cap. I assume these hoses were removed at one time.
Can someone show a diagram or photo to tell me where the hoses should connect?
Also, where is a good place to find new/used parts? I need a few things starting with the Cruise Control Cable.
Thanks!
Mark
Thanks!
Mark
esvanes (10-09-2012)
Thank you for the info.
You are correct about the Lucas cap. Please tell me what the "AAV" is.
I'm hoping someone can post a picture of the top of thier engine. That might help me figure out another hose that I found in the engine bay (front, left fender) that appears to have no place to connect. I know it has to go somewhere!
Thanks again.
Mark
![Talking](https://www.jaguarforums.com/forum/images/icons/icon10.gif)
OK, AAV (Auxillary Air Valve), rear of the LH cylinder head. Among other hoses, it has a 1" hose going from the snout to the rear of the LH air cleaner backing. In that hose is a "plastic" (if you are blessed) elbow that the hose FROM the cap attaches to, thus giving a draught effect to that vent system.
If that elbow is "gone", simply aquire a brass elbow of suitable size to fill the void, which will then outlast the car.
Pristine97XK8Convertible
04-28-2017 11:08 AM
