Dizzy cap, wires. rotor and ignition coil.
Here's the question. When should I consider changing the above items in my 92 XJS V12 convertible? My car starts and runs great and my son says leave well enough alone but I read they should be changed at 50k miles. Mine has 54k.
What do you recon?
What do you recon?
![Icon Santawaving](https://www.jaguarforums.com/forum/images/smilies/icon_santawaving.gif)
Received 10,872 Likes
My car is Marelli and it still has its original coils.
Ignition leads should be inspected and tested to spec. Most will specify the ohms per foot/meter of wire.
Dissy cap and rotor - I would inspect them when you do your service and only replace them if needed. My car is still on the same rotor and cap that was in the car when I bought it 10 years ago. I check it regularly and have never had a problem.
