The to do list!
The to do list!
G'Day Colleagues
Tomorrow may be a big day for me, I may finaly take possecion of a 1990 XJS coupe, 5.3 V12. Price is confirmed and now just upto the mechanic to give it a once over for an alls well. Now if I take possecion I have a list of things in order that I beleive need doing before I am going to be really happy with it,
No 1. Remove the Marrelli distributor and replace it with a lucus one. Use a MSD coil splitter to run the two coils and all the existing Marrelli electrics. I have read Kirby's book and this is meant to be an easy task, but I still don't understand how the advance is going to work?
No 2. Find an exhaust shop to remove the rear silencers and install resonators or straight through pipes, cant wait to get rid of those absolutely Kacky original rear tubes.
No 3. Remove the radiator and have it boiled out, also convert it to single pass. I can easily make up a stainless Y and combine both banks to one.
No 4. Now this could be a long term project, can not see this one happening quickly at all. Must and state again "MUST" replace the GM 400 auto with a manual 5 speed. The bell housing is sorted with this crowd V12 Jaguar Bell Housing I have also found new Tremec Tr3650 5 speed for $1400. These were used behind 5.4l v8 Falcon's. The only thing I'm not sure about is if there is a difference between the TR3550 and the TR3650? The other thing thing is finding a pedal box to suit with ABS. There was one on Ebay but somebody beat me to it, plus wasn't sure if the car was mine at the time and still am not sure.
Well hopefully all goes well, and then we start. May end up being a nice drive in the end.
Pedal Box
There was a complete pedal box on E-Bay UK last week, but not sure if configuration is the same with RHD versus LHD -I would think they would, but I was proven wrong recently on another RHD vs LHD item (Large Headlights).
Just got word, she sold the car before I could get to look at it.
Not meant to be this is the second one thats happened. Before anyone comments I was 6 hours drive away from it, you just can't buy one over the net you have to look at the darn thing first.
Must be Bad Karma, may have to give up on Jags and buy a pushbike.
If it were meant to be, God would have made it happen. Keep looking, the one you want is out there somewhere!
I did the five speed swap, so I can be of some help. where are you located?
I looked at a manual swap but the ABS pedal box is unique to the ABS XJS. Only options are:
1 Find a late model I6 ABS XJS manual pedal box
2 Modify yours and add a clutch pedal and master cylinder.
I am near Liverpool NSW so more than happy to help. There are a few things to look for when you buy.
There is a dealer in the US that sells kits for your own pedal box to get converted to a double for the clutch. But apparently the RHD version you needs a few skills to make it work, like aluminum welding, well I can do that, but the trap maybe once all weighed up may cost me more than just a made one? I think more research is needed.
The LHD and RHD pedal boxes are identical the difference is in the pedal offset.
Forgot to ask how much are you looking to spend? Because the purchase price can often be the cheapest part of the deal.
BTW that $15K is all parts I have done all the work myself (including paint) except rebuild the diff. Albeit I bought a 6.0L V12 go in at $3K.
There are a couple of cheap 1977/6 XJS on carsales (in Sydney) for around the $5k mark. If you are going to some work these can be upgraded easily to later specs.
I have a borg warner t5 with heavt duty gears and it's perfect for the car, shifts like a jaguar should and fits easily.
Received 10,979 Likes
Actually a T5 was my first choice in transmissions but the general conciseness seems to think they just aren't strong enough? I question this, as a standard 5.3 jag is no were near some off our more modern v8,s that they use these box's behind. No offense to the jag motor in that comment!
I'm *not* an authority on this but I think a T5 would be fine if you don't thrash the unmericiful s*it out of it
It was indeed used behind many low/medium-power V8s. Like any trans it naturally has limits, though. I vaguely recall the it was originally designed to tolerate 300 lb/ft of engine torque. A standard 5.3 V12 comes in below that at something like 260-280.
I think many problems were caused when engine power was significantly increased and/or when drivers were abusive (the two often go hand in hand ).
I sent an Email to Fivespeeds that make the bell housing to suit the v12, I asked about the TR3650 as opposed to the TR3550. You would think there's not that much in it but, The TR3650 wont fit but the TR3550 will? OK They are the experts not me. They personally recommended either a TKO500 or 600 or a Ford T5 V8 box not any other. The T5's are easy to find here especially the ford V8 version's not to sure if they used the same box in the XR6 turbo's.
Anyway things are progressing slowly, Ill keep you posted.
Just to add, my "boy racer" days are dead and berried, nowdays I don't brag about how quick I can burn up tyres but how long they can last me!
