Do relay colors mean anything
from my experience relays are just whatever color the manufacturer decides on. I've replaced reds,blue ones, white ones, green ones, and even clear ones that all got replaced by a standard looking black box. All that matters is whats on the inside
Bc xj (05-27-2014)
Received 10,920 Likes
On an '89 I don't think the relay color is significant. As Sidescrollin' says, it's what's inside that counts. Virtually all have a diagram showing the circuit .
Jaguar threw in a few oddballs with diodes that should not be replaced with a generic relay. On the 80s vintage Jags the relays with diodes were identified by a diagonal stripe painted on the case.
Also, be particularly aware the Jaguar used many relays with a 30-85-86-87-87 terminal configuration. In most cases these can not be replaced by a relay with the much more common 30-85-86-87-87A configuration.
All that being said.....
I strongly suspect that some of the different colored relays you're seeing are not relays at all. Jaguar often used timers and diode packs that look just like a relay and even used typical relay-type sockets/connectors...but they most assuredly are not a relay. I've seen these in red, blue, yellow, green.
On later Jags I'm pretty sure the relay color IS significant....but that's a diffferent discussion.
Bc xj (05-27-2014)
