Do you need a HE Fuel Injector Harness?
#62
Injection harness
I actually make these harnesses.
All plug and play as per originals .
uprated wire, moulded plugs, and braided.
also do the ignition harnesses.
regards
Craig
#63
#64
I too would be interested in buying a harness. My 1987 V12 needs new injector hoses so now would be a good time for a new harness and injectors. How much to buy and post to Melbourne?
Cheers, Ian.
#68
Craig (or anyone else?),
I intend to fit a new harness on my pre-HE (even though mine seems quite good and not brittle (perhaps replaced at some point?).
So, if one wishes to lift the harness out of the valley (presumably tie-wrap or similar to inlet manifold?) on a pre-HE, does the harness need to be made longer in places (where?) or will the original length harness be acceptable?
Tks
Paul
Tks
Paul
#69
#70
Hi Safari,
New member to the forum and found your info re harnesses.
Im not adverse to making my own however would be interested in a pre he either made $$, or just the supply of a kit or 2 to make as making is part of the resto journey.
Why i ask is that so many comments, links etc for harnesses but you came up as the “go to guy” assume the wire and connectors you use are high temp and better than ome.
cheers justin
cheers justin
#72
Loom pre HE
Hi Safari,
cheers justin
cheers justin
jagyrsrus@yahoo.com
