does anybody have a decent picture of the fan bearing mount?
I am restoring the engine driven fan that the DPO made go away.
I think I see how the fan bearing fits in there, but does anybody have the front of their engine apart far enough to post a picture?
I'd be a lot further along if this making a living thing would keep getting in the way.
Steve AKA 71MKIV
71 Triumph Spitfire
91 Jaguar XJS convertible classic edition
Every 20 minute project is one broken bolt away from a 3 day ordeal.
Steve AKA 71MKIV
71 Triumph Spitfire
Hi 71MK1V
Not sure what you meant by Fan Bearing, did you mean the Fan Clutch?
Putting a New Fan Assembly on is quite easy (in the Scheme of things) although a whole lot easier with the Top Closing Panel off
This Pic may help?
The Mechanical Fan in its Shroud
The Fan Shroud
Fitting the Fan is easier with the Top Panel Removed
This Pic may help?
The Fan Shroud
Here is a head on view of the mount with pulley and studs on my V12.
Here is a straight down pic on my engine before:
This link will take you to even greater detailed pictures of the fan bearing, mount and housing going through an overhaul etx.
In pieces
Fitted to engine
In pieces
Fitted to engine
You are best to change the bearing as well. Problem is, the original bearing is now NLA. You can use a water pump bearing though. The Wizard of Oz (Grant Francis) had one sorted for me before I found the last bearing available... (at that time).
So I have a dumb question.
Is there any reason just to find two off the shelf bearings and make a new shaft? Can't be that difficult to do.
41L40, case hardened, couple circlip grooves, how hard can this be?
Steve
71 Triumph Spitfre
"hang on, this totally worked in the video game"
Steve
71 Triumph Spitfre
Jsedita74
19
12-08-2012 09:37 PM
prelude4ws
09-16-2010 01:22 PM
prelude4ws
09-16-2010 02:19 AM
androulakis
01-18-2010 12:57 PM
in2town
XJ40 ( XJ81 )
10-15-2009 03:32 AM
