Door Actuator Clicking SOLVED!!!
I've started several previous threads discussing my downward spiral of a failing door lock actuator. I have found the solution!
So I did all sorts of electrical testing, connector swapping, short circuiting and finally I plugged in the two actuators I had into the working drivers side harness and they both still didn't work. I actually bought a used failed unit!
For some crazy reason I started actuating the locks and squeezing the housing. I found that if I applied pressure to the actuator housing, it worked! No excessive clicking. It also needed to be connected to the linkage so that it would know when it had traveled it's required distance. If the linkage wasn't attached, it would keep actuating up and down.
In the end, I wrapped it tight with some nylon zip ties and it seems to have done the trick, although I need to find a better solution than that.
There is something about the actuator's plastic shell that come undone and allows that actuator to keep clicking after it's done it's job. For now, zip ties, but I feel that I will need some kind of ratcheting belt to go around it it really keep it tight.
Can someone explain what is happening to this thing?
Vee,
Well done for finding the problem! It just goes to show that we shouldn't take anything for granted! I assumed that you had bought a new unit so didn't even think to suggest that you might have a faulty replacement unit!
Looking forward to you taking one of them apart to understand what's happening in there!
Paul
Paul
I
Your cable ties have made the thing solid again. probably MORE solid that when new! So it is probably a very decent repair, in reality.
Greg
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
