Door chrome help
Door chrome help
I’m stripping my XJS for paint prep and have most of the chrome removed, but the chrome strip at the base of the main windows would appear to be riveted in place (though I did see a post where someone said it was held in by screws, but that doesn’t appear to be the case on mine).
Any tips on getting this off? Thanks
All the XJS doors I've worked on were riveted.
The rivets need to be drilled out to remove the chrome strip.
When I worked on mine I bought a few of the Jaguar Pop rivet kits.
They are not standard, they have extra long grip wires, and you can't use the standard tool to insert them.
You can use a standard tool if you use a ferule spacer to keep the tool away from the door.
I have one kit with the ferule left if anyone wants it.
MrAndersonGCC (07-11-2022)
It’s looking very doubtful that I’ll be able to get the rubber weatherstrip off in decent shape. The old ones are a little brittle.
Is there a specific one for the XJS or can I try to use something generic? Frankly I’m not even sure what the common term is for these.
MrAndersonGCC (07-12-2022)
Ok I just cut off the rubber piece on the driver's side...no chance it was coming willingly and intact anyways. Before I start drilling out the rivets, I have two questions:
1) How do I access the rivets on the section of the chrome strip that extends down to the quarter window (that's what I call it...the trapezoidal piece of glass in front of the main window)? I see a "ledge" there with 3 screws; I removed them but the ledge doesn't really want to budge.
2) As for reinstallment of the chrome - I suppose I could just use small screws instead of rivets, right? Certainly there's a short enough screw with the right thread pattern to fit in the rivet holes.
2) As for reinstallment of the chrome - I suppose I could just use small screws instead of rivets, right? Certainly there's a short enough screw with the right thread pattern to fit in the rivet holes.[/QUOTE]
My advice would be to NOT use screws to attach the chrome strips.
Since the existing holes are the same size, you would need to open the holes in the chrome strip to accept whatever fastener you use.
The metal would probably buckle from the drill and the head of the fastener would interfere with the rubber strip.
Pop rivets were used for a reason.
Pop rivets were used for a reason.[/QUOTE]
Sorry, I'm confused about a couple things you mentioned:
"Since the existing holes are the same size..." --> I assume you're referring to the hole in the chrome and the body's metal - in which case, what's the significance here? If I can find a screw small enough to fit the existing holes, I'm not sure what the problem is with sizing or why anything would buckle.
In regards to the screw head, the head of the pop rivets are very similarly shaped to your typical small body screw - nearly semi-spherical in nature. Finding a screw with an equally shallow head would be a piece of cake.
Btw - I did manage to get the so-called "quarterlight" glass structure removed - there was quite a bit of sealant that prevented it from budging...a heat gun is recommended here, my friends.
The silly chrome pieces have been removed. I am debating the best method of reinstallation. Even after removing the rivets and screws, it did not come without a fight. I certainly applied FAR more force than a window rolling up ever would, so I may try to just use sealant to reattach. Messier, but much much easier to remove if I ever have to again. God I hate rivets.
