Door Lock Issue
Old 12-25-2014 | 11:29 PM
Bc xj's Avatar
I did the same with my passenger door locks. I worked the inside handle, outside handle and key at same time. Multiply combos over and over then it freed up and worked ever since.
Also randomly sprayed penetrating fluid inside door through window slot handles and lock
Old 12-29-2014 | 07:57 PM
pat_opsahl's Avatar
Sorry about latching onto the older thread, it was very relavant to my problem. And my bad for not describing my kitty - 1996 XJS convertible with the 4.0 litre AJ16 motor.
Using the key in the drivers side door lock and turning CW, always unlocks. Turning CCW does not lock? Feels like the key pyhsically can't turn far enough?
I have located remote lock fobs online. I want to make sure my car has a remote system from the factory - how do I tell?
Old 12-30-2014 | 05:34 AM
malc4d's Avatar
On the earlier models the control unit sits behind the right hand trunk side panel. A box is fixed behind the rear light and has cables that go to a big white cable connector
Link to programing remote
https://www.jaguarforums.com/forum/x...emoval-128608/
JarodL
03-07-2024 02:39 AM
99xk8guy
06-05-2023 07:28 AM
PMKimpton
08-03-2019 09:22 PM
XJsc-guy
11-23-2015 02:56 PM
obwoodie
09-03-2015 08:45 PM
Quick Reply: Door Lock Issue
