Door panel removal
Door panel removal
Is there anything special to removing the drivers side door panel?
When I took the outside mirror off the replace it (it vibrates badly when driving and was told on this forum that indicates the internal spring has broken) the wiring connectors fell back thru the access hole. I fished one of the connectors out but can't locate the second one. The only way to get to it appears to be from inside the door.
Look under arm rest, remove screws and door handles and knobs and mirror chrome. Then pry the panel away from door starting at the handle side and move down and around to the other side. Any resistance look for screws, the lift loose panel up. Careful of the old stuff. reverse to put back.
BradsCat (02-26-2017)
