Door Window Dilema
Old 11-16-2015, 01:51 PM
xjsrookie's Avatar
Default Door Window Dilema
I just replaced the bezel around the window and convertible top switches, easy install, now the door windows do not work. Contacts are clean & tight. Connectors are locked in place. Is there another fuse besides the Thermal Breaker and if so, where does it hide?
Old 11-19-2015, 07:35 PM
kenatofc's Avatar
Do not know where the secondary fuse is... Someone else will probably chime in on that. If you are willing to spend some time in removing the door panel... About 10 minutes if you are careful, you can disconnect the two wires to the motor and bench test with a 12V power source and if working, you can rule out the window motors. Therefore the problem is between the switch and the motor.... So, it is late and this is probably not very much help anyway..... both motors do not normally go out together. I would guess it's the switch. Perhaps they were not put back in correctly.. OH well, hell. I'm not much help this evening... sorry
Old 11-19-2015, 07:55 PM
Most likely you just popped the fuse. Have you checked them?
It would help if you told us the year of your car. Then one of us could post the wiring diagram to help you understand the circuit and diagnose the problem.
Mark
Old 11-19-2015, 09:01 PM
FastCat85's Avatar
You can take a volt meter, with ignition on, and test for 12 volts DC on two outside female terminals (each switch has two pairs) of each window switch plug.
One will read +12 and the other side of plug should be -12 (or reverse)
I had to take a small round file and clean the inside of the connectors on the plug to get my
window to work.
Buckingham
10-06-2016 12:22 AM
TweeTwee
11-09-2015 11:43 PM
trulycar
11-03-2015 09:45 PM
Jagrx
10-22-2015 01:15 PM
XJDanny
10-20-2015 08:40 AM
Quick Reply: Door Window Dilema
