Doors
Old 04-18-2017, 03:58 PM
brinny's Avatar
Default Doors
My 89 convertible doors are in poor shape. Does anyone know if I could use coupe doors and simply remove the window frames and swap over any necessarys. I have had a measure and the door body shells appear the same? Many thanks in advance for any help lads
Old 04-18-2017, 06:40 PM
warrjon's Avatar
Received 2,576 Likes on 1,712 Posts
I know the 89 coupe doors have the window frames welded to the door whereas the convertible has frameless windows.
If it's rust in the bottom of the doors it would be easier to cut it out and weld new metal in.
Old 04-23-2017, 04:18 AM
Paul_59's Avatar
Banned
I don't know if facelift doors are the same size, but I do know that my 93 6.0 facelift coupe has frameless door window
Old 04-23-2017, 04:53 AM
Daim's Avatar
Received 2,181 Likes on 1,584 Posts
The door size is the same. The skins are different, due to different handles.
Old 04-23-2017, 08:43 AM
Some Day, Some Day's Avatar
Received 1,049 Likes on 668 Posts
Coupe doors from the early facelifts should work, as they have the old-style lift-up handles that my wife hates.
Old 04-23-2017, 11:47 AM
Daim's Avatar
No they won't as all prefacelifts had the little quarter light and the window had a frame. Again, welded.
Old 04-23-2017, 05:18 PM
But would you need those quarter lights? If the shape's the same, just get some vehicle-side sealing strips for the A pillar and replace the whole thing.
Unless it's never that simple....
Old 04-23-2017, 10:47 PM
Daim's Avatar
It's never that simple as the hinges changed as well
Old 04-23-2017, 10:58 PM
Naturally.... ツ
Where are all the emoji in this horrible new format?
