Draining excess transmission fluid
Received 10,979 Likes
Grant Francis (11-07-2023)
I am with Doug here.
Also, check the hose TO that Modulator, it lasts about 5 years, exhaust pipe is TOO close. I wrap a small bit of header wrap around the exhaust at that point, worked so far.
Remember, when replacing that hose, it MUST travel BEHIND that heat shield, or you will do it again in a few days. Use the old hose to drag the new hose through the gap, simple.
JJS- Florida (12-01-2023)
Got a chance to get under it today.
The hose to the modulator is intact, no signs of heat (or other) damage.
I take it that if I replace the modulator that I'll need to drain the fluid again?
I replaced the governor (due to stripping) earlier this year. I'll pull it out and examine it since I'm nearing the end-of-the-line on what to do.
Thanks,
John
1987 XJ-S V12
about 75,000 miles
Thanks,
John
1987 XJ-S V12
about 75,000 miles
Grant Francis (11-15-2023)
If it helps, I recently refreshed my transmission fluid with multiple suction/refill sessions.
I used this 12v pump:
https:/www.ebay.co.uk/itm/353531098461
Very easy operation, warm fluid was all sucked out & within about 5 minutes max.
The amount of fluid I removed each time was completely consistent - between 3.4 & 3.6L each time - I think this is close to the amount you'd get out when dropping the pan so I would recommend the suction method for ease/quickness.
I jus replaced exactly what I removed each time, & now have nice red fluid instead of reddy-brown.
End of the line maybe...
Finally found someone who will work on the transmission. They said it either needs to be rebuilt or replaced, at an estimated cost of $7,000!
I don't have the capability, knowledge or equipment to even take the thing out, let alone rebuild it.
I see rebuilt TH400's available for around $2,000. But if I understand correctly, the case for a typical TH400 won't fit in a Jag? Is that correct?
Thanks,
John
1987 XJ-S V12
75,000 or so miles
Thanks,
John
1987 XJ-S V12
75,000 or so miles
It doesn't cost $7K to rebuild a TH400.
The TH400 for GM cars won't fit the jag engine block.
I believe all the internal parts are the same, though.
I remember back about 1988, I needed some work done on my '76 XJS, it was simple work, like replacing the brake pads.
I took it to a shop across the street from where i worked at the time, to get a quote.
The owner came out and looked at the car and said $5000.
I said a brake job doesn't cost $5K, even on this car, and he said "Jag owners and Porsche owners are all ********, they complain about everything, so it costs more to work on their cars".
Essentially telling me to get lost.
Doug
Doug
#28
#30
The following 2 users liked this post by AZDoug:
Greg in France (12-16-2023),
LnrB (12-15-2023)
#31
Yep, I don't know how places stay in business charging twice what a job should cost.
What's also annoying about the first place I tried is that they didn't trouble themselves to reattach the shifter, so I can't even back it up a foot (it's sitting on a slight downhill slope). Jerks :-)
Thanks,
John
1987 XJ-S V12
75,000 or so miles
Thanks,
John
1987 XJ-S V12
75,000 or so miles
#32
Greg in France (12-18-2023)
#33
Received 9,441 Likes
