drive cycle
Received 10,867 Likes
Received 2,260 Likes
drive cycle
a drive sycle is what you do through by driving your car for about a week after you receive a "check engine lite" comes on. Once the problem has been fixed and the check engine lite does not come on after the car is re-started you drive it at different speeds for about a week to re-set the cars inboard computors monitors so they can reset them selves and see if it will pass the emmisions test. My state gives me three chances. These drive cycles are supposed to set the car's emmission monitors sooner than having to drive longer to receive the same resulte. Here are a couple. that I found for a xjs 4l 6 cyl. It would be easer if I could upload them;
CAUTION:
The vehicle should be driven approximately 7.5 miles within a period of approx. 23 minutes (1372
seconds) from a cold start. However, due to manufacture variations, it is necessary to perform only as
much of the Drive Cycle as is necessary to reset the required monitors to a "Ready" status. Operate the
throttle smoothly to obtain best results. Do not turn the ignition off during the drive cycle.
CAUTION:
Obey all traffic laws and drive in a safe manner!
NOTE:
Extreme driving conditioning such as very high/low temperatures, rough roads and high
altitudes may prevent some monitors from attaining a "Ready" status.
Step 1 (Engine Cold) Start engine, idle 20 seconds. Accelerate gradually and drive at 20-25 mph for
1 minute, varying speed.
Step 2 Accelerate gradually to 32 mph within 35 seconds. Decelerate to 0 mph in 10 seconds. Idle for
40 seconds.
Step 3 Accelerate at part throttle to 25 mph in 10 seconds. Cruise at 17-25 mph for 15 seconds.
Accelerate gradually to 57 mph in 45 seconds. Cruise at 50-56 mph for 1 minute. Decelerate
gradually to 0 mph in 40 seconds. Idle for 15 seconds.
Step 4 Accelerate at part throttle to 36 mph and maintain for 10 seconds. Decelerate to 0 mph in 15
seconds. Idle for 5 seconds.
Step 5 Accelerate to 30 mph and back to 0 mph within 30 seconds. Idle for 20 seconds.
Step 6 Accelerate to 36 mph in 20 seconds. Drive at 35 mph for 20 seconds. Decelerate to 0 mph in
15 seconds. Idle 5 seconds.
Step 7 Accelerate gradually to 26 mph and decelerate to 0 within 40 seconds. Idle 15 seconds.
Step 8 Accelerate to 27 mph in 40 seconds. Decelerate to 0 mph in 10 seconds. Idle 25 seconds.
Step 9 Accelerate to 26 mph in 15 seconds, maintain speed for 10 seconds, decelerate to 0 mph in 10
Step
Accelerate to 23 mph in 20 seconds, decelerate to 0.5 mph in 10 seconds (no complete stop).
Accelerate to 28 mph and back to 0 mph (momentary stop 1 second) within 35 seconds.
Step
Accelerate gradually to 34 mph in 45 seconds. Vary speed between 34 and 19 mph for 2
minutes. Decelerate from 25 to 0 mph in 25 seconds. Idle for 5 seconds.
Step
Accelerate to 29 mph in 15 seconds, decelerate gradually to 0 mph in 45 seconds. Idle for 30
seconds.
Step
Accelerate gradually to 28 mph and back to 0 mph (momentary stop 1 second) within 50
seconds. Accelerate gradually to 27 mph and back to 0 mph within 55 seconds. Idle for 15
seconds.
Step
Accelerate to 24 mph and back to 0 mph within 18 seconds. Idle for 10 seconds. Accelerate
gradually to 22 mph and back to 0 mph within 50 seconds. Idle for 8 seconds.
Step
Accelerate gradually to 30 mph within 50 seconds. Decelerate to 0 mph in 10 seconds. Idle for
25 seconds.
Step
16
Accelerate to 23 mph and back to 0 mph within 30 seconds. Idle for 10 seconds.
Step
17
Repeat steps 1 - 16 once again. Recheck the status of the "Readiness Monitors".
NOTE:
40 seconds.
Step
Step
Step
seconds.
Step
seconds.
Step
Step
25 seconds.
Step
16
Step
17
NOTE:
Remember, clearing DTC's or interrupting power to the ECM after the readiness monitors have
been reset to "Ready" will require that the Drive Cycle be repeated.
No joke Mikey, least if it is, it is all over the Net for all sorts of cars and all different.
What gets me is the way that the figures are so precise.
How in hell is one going to achieve anything after step one?
OK I suppose one would manage the various idle stages without too much trouble.
But the rest, no way.
It might be my ignorance talking but.... I thought that to reset the car's computer all you need to do is to unplug the battery for a little while... if not, it probably will be easier just to take it to your local auto-parts store and ask them to reset it for you.... I think they will do this for free... same as scanning for codes...
If you didn't pass an emissions check at an inspection station after the "check engine lite" went on you usually have an emissions problem. When the car is fixed and the "check engine lite" does not come after the car is started it indicates that problem has been fixed. But the various monitors, sensors and actuators that send information back to the car's computer need to have the car driven for a while, usually a little over a week, to report to the computer that everything checks out. This is called the "OBD Service drive cycle". Driving the car for a while should ensure that all diagnostic routines are exercised.
1996, 2003, accelerate, computer, cycle, cycles, drive, drivecycle, ebjcoebjcohypermartnet, engine, jag, jaguar, resetting, xj, xjs
