Driver side window won't work
If you get nothing, next thing you could do is pop off the door panel and plug a 12v power source directly into the window motor after unplugging it. Try a combination of connections, reversing neg and pos switches between up and down.
If that doesn't work your motor is kaput. Remove the motor and regulator and try to operate it out of the window, without load. If it works then the gears are worn or the motor has had it.
I don't recall much of the circuit, so if they work with direct 12v but don't work with the known good passenger switch, there is something between those causing a problem, usually bad ground.
Post with any more info you gather, so we can help you out and assist in diagnosing the problem.
I just replaced my drivers side regulator and motor because the gears stripped out.
dickc (10-08-2013)
I had to fit a new one of these a few years back.
Part no. DAC11334 | Window lift thermal cut-out switch parts from Jaguar Classic Parts UK
dickc (10-08-2013)
Same problem with my 89 xjs. After bench testing the motor while installed, found that the window is sticking in the window channels or the bailey channel.... will disassemble this winter and find out where it is sticking... but motor and switches are ok. Don't throw money at the problem until you know what the problem is !!
Ken in wild and wonderful WV.....
dickc (10-10-2013)
Also, this was sent to me by Razkid and is a good place to have for lots of items:
Looking for repair info or TSB's?
1. click on link :http://www.powerlibrary.net/Remote/R...p?ID=meadville
2. enter the following as the code: pl249412345678
3. click on Auto Repair Reference Center in the middle of the page
4. and you're in! find your model, year, make etc...
In this reference go to: EBSCOhost: Scegli database
The reference and how to on checking / solving the problem.
good luck
ken
good luck
ken
xjrjag
10-27-2021 11:48 PM
