Drivers Side Seat
Drivers Side Seat
I am the proud new owner of a '94 XJS Convertible 2+2! I am beginning to sort out a few things that are not working. Any help would be greatly appreciated.
Seats all appear to work with the exception of the drivers side. The drivers side back moves forward and back, lumbar works, just that the seat bottom won't move forward but about three inches. It apprears the motor engages and move three inches and stops?? Motor works, seat moves, just not enough forward for my wife??? Any ideas? Thanks!
Congrats. Welcome to a very unique club. I haven't actually measured but i don't think the seats actually move fore and aft very far, although 3 inches does sound a bit restrictive. When the seat is all the way back, look under the front of it. There is a big ribbon cable connecting the control box to the seat.... Have a look and see that ribbon cable isn't messing with the seat track
Ribbon
The black ribbon is visable and plugged in. I had heard about that one. The only thing that is not working is how far the seat moves. Like I said, it moves maybe two-three inches back and forth, just not enough forward for my wife to comfortably drive? Maybe thats not bad? Wrong, the car is for her! Happy Wife....Happy Life!!
Barrie Parkinson (05-10-2022)
On my '94, the passenger seat will continue to move fore/aft for as long as you hold the switch. However, on the driver's side it will only move a couple of inches fore/aft regardless of how long you hold the switch down. Another press of the switch in the same direction moves it some more, etc, etc, etc. I always saw it as intentionally designed that way, kind of a safety cut out or something.
Looking into pulling seat
I tried moving the seat forward in increments and that did not work. I have also tried to see if there is something blocking the tracks. I now am left to maybe pulling the seat to have a closer look.
From what I have read, to pull the seat, you remove the two screws on the rails on the front side and lift up on the seat?? I will disconnect the electrical first. Is that the correct proceedure for pulling the seat?
Thanks again for all the suggestions! Keep em coming!
"passenger manual seat"
Hello I have a 94 xjs , and I just took the passenger seat control module out. The Black plug with the bigger pins was melted and it ruined the plug as well as the module. I could very easily get another module and plug and put it back in , but I don't want it to happen again . So that's why I would love to find a manual seat track for it and know that it won't. You mention you have one with a manual seat ? Do you or anyone else know where I can get one for this car?
Start a new thread. Give a little more info and explain what you are looking at, experiencing. You'll get some help, no doubt... I didn't check your profile, but if you haven't already included it - give make , year model and all that good stuff.
Of the seats don't move at all it can be a problem that involves hot wiring the seat (I'm not so familiar) or cutting the bolts out, if possible Sounds worse than it is. Could be a fuse, a relay... Start a new thread 😸
LnrB (01-09-2022)
Mine driver's seat does exactly like this. Have you find out what is the problem?
I seriously doubt that by design you have to push button 20 times in order to move Driver seat from front to back. Also - passenger seat works fine - just hold the button and seat slides nicely the whole length front to back.
I have also 1995 XJR and this also had this strange error, that it you hold the button it moved seat a bit and then it stopped. Also the memory function did not work. It turned out it is the common error of X300 seat positioning sensors. They brake inside and cant tell the computer correct position and that causes this strange behavior. It is possible to open the sensors and repair it (there are nice instructions for this job also in this jaguar forum under X300 section). I have done it and they work well now.
I suspect that this can be the case also with facelift XJS seats, maybe these also have the same sensors that X300 of this era has. I searched all "seat" keyword topics (9 pages ) here in XJS forum but found only this topic that mentioned this error. So it seems to be not so often appearing error and there seems not to be instruction to fix it
Jon
