Driver's window help
Yup, both windows are on the same fuse. If your passenger side window switch works, before tearing into the driver side door, I'd say open up the center console and temporarily switch the plugs (just pull the wire harness from them and stick it on the other switch), and see if that works. If so, then it's just the switch, which you can either take apart and clean, or just get new switches. I got a pair of switches for my 86 off of Amazon for less than 8 bucks a piece, now both windows work perfectly.
99xk8guy
06-05-2023 06:28 AM
RaceDiagnostics
09-13-2015 02:22 AM
