Drove my XJS to work today for the first time...
So my new to me 95' XJS made its first trip on the road today after sitting for 4 years.. Other than the tires being severely flat spotted, the car ran great.
Getting tires installed later today. AC is the only option I can find that does not work. Found the original owners manual under the passenger seat and read it over last night.
I am also replacing:
All coolant hoses/coolant
All brakes and flush the system with new fluid
Change the Transmission fluid/filter
found a few relays that were bad
Belt/Belts
Spark Plugs
Car only has 56K miles on it.
Belt/Belts
Spark Plugs
Received 10,871 Likes
Received 6,307 Likes
When you're all done a bullet point narrative of everything needed to recommision the car would be great, IMHO. It seems like many people consider buying Jags that have sat unused for years. It would be helpful if they had a real world example from someone who has been there....just so they know what they're getting into.
Just an idea.
Just an idea.
jag 1990 xjs 60k miles
what i am doing/did:
--all new spark plugs and wires
--rotor, cap
--all coolant hoses, thermostat
--radiator
--belts
--removed mechanical fan, replaced with electrical
--brakes flushed, new pads, rotors in front...found a faulty caliper on pass side was replaced
--air filter
--removed exhuast, replaced dual cats with single pass each side, removed resonators mid car
--power steering rack new hoses, replaced bushings, new fluid
--new battery
--all new fuel hoses, engine bay....
--i broke a couple of things and was replaced in engine bay
--new vacuum tubing
--removed fuel tank, sealant on inside, new washers
--cleaned out sump....new hoses all around
--new windshield sealant/rubber and rear window
--rotor, cap
--radiator
--belts
--air filter
--new battery
--new vacuum tubing
I'm looking forward to doing the same thing one day. I have two jags - both xjs v-12 one 78, one 79. the 78 sat around for 18 years after being purchased by the gentleman I bought it from. Its a recovered theft and has only done 25,000 km. the white one I bought as a donor vehicle, but as I couldn't bring myself to part it (second owner with 58,000km on the clock) I have just finished buying all the suspension, brake and engine parts I need to turn it into a real gem. Hopefully my day to drive it will be in around 8 months!
I have started a blog for anyone interest with pictures and commentary Jaguar XJS V12: It's Here!
I am in the same boat
I have been doing a budget restore on a 1987 XJS Hess & Eisenhardt convertible. I have had to replace the hoses, belts, plugs, shocks, tires, exhaust, brakes, radiator, fan clutch and many misc. items. I have been able to store my Jag at work where I can also work on it. I am finishing my second masters degree, working 2 jobs and all the other things involved with living. Working on the Jag is a blast! I turn on the classical music, put on the shop coat, take a big drink of water and began the days adventure. I am about a month away from stage one which is simply getting it running and on the road. I cannot wait! The only problem I am currently having is all of the drool marks being left on the car by everyone who gets near it. Isn't there some sort of anti-drool polish that Jaguar put out for just such a situation as this?
Schoe
Schoe
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
10-19-2015 09:44 PM
Fraser Mitchell
10-01-2015 04:06 AM
