Dual electric fans
Depending on where you are, here in Aus, the Ford AU falcon is nearly identical to the xjs in size, this is what I have read. Sorry can not think of who had this information came from at the moment but I did look into it. You can buy a complete unit with cowl and fans for around $100 on Ebay, I was just given one from a friend. I wont install mine till I do the Motor\gearbox transplant.
dickc (03-25-2014)
Received 10,876 Likes
I've often wondered if the dual fan assembly from an X300/XJ6 would work?
Jaguar 1995 to 1997 XJ6 Radiator Cooling Fan Assembly MNC4270AC | eBay
dickc (03-26-2014)
That diagonal mounting would be tricky for me.
I found this site with fans and kits: v12s Jaguar XJS V12 Aluminum Electric Cooling Fan Systems
May be a little pricey but may be worth it.
Thanks Doug,
Dick C.
Here is the site I got the intial information from, funny when things come flooding back to you. Lots of good information here.
Enjoy!
XJ-SC Modifications
Enjoy!
XJ-SC Modifications
Thanks Katoh!
Fan's power is much enough to cover the V12's heat though. So if remaking the shroud is not a problem it could be a good option.
dickc (03-27-2014)
Hi Doug, the X300 fan shroud is too square for an XJS, so it needs to be cut down and remade to fit in the XJS's engine compartment. My acquaintance mechanic did the job, but he said it was totally a hard job to do.
Thanx,
DickC
Collector1
09-28-2015 03:52 AM
