Duct tape: never leave home without it
So I narrowly averted an overheating disaster today with my '94 AJ6.
Decided to take it for a nice day-off drive to the mountains. About 30 miles from home, I noticed a bit of stumbling coming off a stop sign, then I saw the Temp gauge was almost at the red. I slowed down, turned off the AC, starting trying to figure out the problem. I was on a nice NW Georgia rural blacktop, just surrounded by farms, but fortunately I knew I was just a few miles from a corner country store. Made it, pulled to a stop as smoke started coming from the hood. Trip computer told me to check engine, FF14 ("FF 14").
Well, coolant was all over the front top of the engine. So I let it cool a bit, went inside, bought some coolant ($11), filled it, cranked the motor, and the radiator fan was spraying it everywhere.
Culprit was the top radiator hose, where it is clamped to the motor. It had a split underneath, about 6" long.
I had no tools, nothing. Several good ole boys stopped to chat and offer advice. But the corner store had a wrench ($6), a pair of pliers ($7) and a single roll of duct tape ($6 - maybe about 10-feet worth). So I undid the clamp, pulled the hose, and wrapped the radiator hose with duct tape, about 3 layers worth. Bought more coolant (2x$11), topped it off, cranked it, all was good.
I decided a retreat towards home was best, and babying the car, I made it home with the Temp gauge never much above N. By the time I got home, it seemed to be leaking again, just a little.
So, lessons learned:
1) Never leave home without a robust tool box.
2) Never leave home without extra coolant.
3) Never leave home without Duct Tape!
Oh, and 4) always have a large bottle of water on hand ($2). My puppies had to sweat it out while I made the repair.
So how did this happen? Partly my fault, I suppose. A couple of weeks ago, I pulled that hose to get at the crank position sensor and install Andy's Bracket. I should have replaced the hose while I had it off. 136k miles on the car, so replacing a lot of hoses will be next on my to-do list.
I was really hoping to do some sport-mode driving in the mountains with the new Andy's Bracket, there's a noticeable difference.
But at least I made it home. Total cost, about $55.
Next up. Rockauto to buy some hoses.
Padre
Padre
Jonathan-W (08-17-2016)
Been there with my XJ8... I ended up stranded 50 km from home, 20 km from work on the Autobahn. Used my bottled water. Lost 1l every 5 km... So I was constantly stopping amd using expensive water... Repaired it with some duct tape (little tear, about 2 cm long) and replaced the hose 2 days later.
Received 2,399 Likes
Duct aka Duck tape is great stuff. Baling wire, Duck tape and WD40 !!!!
Actually, there is a dedicated version for water hoses. Each of my cars has a roll. So far, so good, unneeded.
Old axiom is true. If you have it, you will likely not need it. If not, 'the flip side".
Good work....
Carl
Good work....
Carl
FWIW, I carry basic screwdrivers, duct tape - silver AND clear along with a garbage bag, a fire extinguisher and a charged cell phone at all times in my 1990 convertible. I'm not sure I have the skills to put them to full use, but I do have them in a pinch....and admit to using the phone a couple of times so far, and the tape and bag to cover a window that was stuck down, also.
Anthony8858
08-18-2016 12:31 PM
