Early 93 Convt. w/sport Pack Help!
aaf8 (07-08-2016)
Greg in France (07-09-2016)
How are the eibach springs different from stock? Are they stiffer and lower the car a bit?
I am currently run stock springs(from and barratt) and bilstein shocks (some random bilstein distributor online)
86jag,
The Eibach springs were developed from the Aston DB7 springs by Ray Ingham to be a replacement sports spring. When I first fitted them with adjustable Gaz shocks, the rear rode a little lower than standard. I then fitted the new adjustable platform height Gaz shocks and was able to get my original ride height back. With the adjustable bounce / rebound adjustment, you then dial in your preferred ride characteristic.
Paul
Paul
Greg in France (07-11-2016)
Received 10,920 Likes
aaf8 (07-12-2016)
As Doug correctly says on the 93.5 MY (US 94MY) onwards "Sport" switch has the following effect :
Normal mode "provides economy operation by causing the transmission to upshift at lower engine speeds and throttle openings. Start off occurs in second gear unless accelerator is pressed to kick down position.
Sport : "Sport mode allows the engine power to be used to its full potential at all times. Start off occurs in first gear and upshifts and kick down are tailored to performance"
FS[MidWest]: Parting Out 1997 XK8 Red Conv
CyJag
59
10-21-2016 04:33 PM
