Early Thottle Position Sensor now available
Guys
FYI, the original, black coloured TPS, the Bournes type, with three lugs that fits under the throttle capstan, has been unavailable for over a decade. Well I have just bought a new one from David Manners. It is Part Number EAC2670*.
This means a new TPS can be fitted directly to the capstan on pre-(about) 1988 V12 HEs, without having to have the capstan adaptor that is required if the later, small two-lug red TPS has to be used.
Greg
Greg
The following 7 users liked this post by Greg in France:
cat_as_trophy (04-24-2017),
Daim (04-02-2017),
Doug (04-02-2017),
Grant Francis (04-02-2017),
JigJag (04-02-2017),
and 2 others liked this post.
Received 10,920 Likes
JigJag (04-02-2017)
I see them available for US $137.87 , is that the one? I think I should replace mine while throttle assembly is off the engine.
Did anyone explore exchangeability with other brands? I see TPS-es for bunch of models in $10-15 range. Is it anything more advanced than 6Kohm potentiometer with 90 degree rotation?
I used a Mustang TPS and it worked fine. Info in this thread.
https://www.jaguarforums.com/forum/x...or-best-32774/
Others have had both good and poor results with the same mod
Hmm... per that thread mustang's TPS "is compact and rotates in the right direction with a 270º swing."
How is 270º swing work when our throttle is wide open at 90 deg.
I measured my TPS to have 6k resistance, the 'slider' seem to reach both ends at the ends of 90deg turn and that make sense as it would correspond to 0 - 100% openning .
Does anyone know total resistance of mustang's TPS, and if it will reach 'other end' at 90 deg turn?
Thank you.
Thank you.
Greg
Thank you.
Thank you.
The 270º statement in the previous write-up is incorrect. The Mustang TPS is 90º swing
