Efficient route to run wire from engine compartment to battery?
Old 04-30-2017 | 07:25 PM
Connor Benenati's Avatar
Default Efficient route to run wire from engine compartment to battery?
Wiring a fan controller directly to the battery. Anyone have experience with a location to run wiring from the engine compartment to the trunk of the car where the battery is located?
Once I'm in the cab I think I can handle it but I'm stuck at the firewall.
Any help is appreciated.
Old 04-30-2017 | 07:47 PM
warrjon's Avatar
If you mean engine bay fans, there are 2 positive terminals on the firewall behind the cam covers in the engine bay, DEPENDING ON THE MODEL of XJS.
Old 04-30-2017 | 07:49 PM
I have a 1987 XJS, installing a fan controller for a new 16'' electric rad fan.
Old 04-30-2017 | 08:58 PM
baxtor's Avatar
As Warren said there are two posts on firewall that will dwarf any additional wire you might run back to battery.
Old 05-02-2017 | 01:36 PM
orangeblossom's Avatar
Hi Connor
Here it is right at the end of the Yellow Screwdriver Handle, under a rubber Cover and there should be one on the other side too.
The 12volt Firewall Terminal is at the end of the handle of the Yellow Screwdriver under a rubber cover.
Old 05-02-2017 | 03:41 PM
Vee's Avatar
Vee
How about some help with your model year and engine?
Welcome to the forum. Please create your signature now so you don't have to remember next time.
